Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
tama123 (guest)
Guest
Posts: n/a
I cannot find anywhere in this article a description or steps to remove the Vibration/dampener pulley or what size the pulley bolts are. Does anyone know? E-12 E-14 larger ?. Also I've been told buy a couple local mini mechanics that if you are reaching 100000 miles or so changing the timing chain tensioner to the older version or 82mm to help with timing chain stretch at or around 100000 miles is pointless. Is there any truth in what some suppliers state that the 82mm tensioner will help with stretch and quiet a noisy chain on start up? Thanks in advance.
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Turbocharged Engine Timing Chain Guides Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 09-22-2016, 04:07 PM
Nick at Pelican Parts's Avatar
The steps needed before the procedure are listed. All articles are here:
http://www.pelicanparts.com/techarticles/MINI_R56/MINI_Cooper_R56_Tech.htm
- Nick
Administrator
Luccia at Pelican Parts's Avatar
Harmonic balancer tech article here - MINI Cooper R56 Crankshaft Pulley Replacement (2007-2011) | Pelican Parts DIY Maintenance Article. Figure 4 tells you the size of the torx bolts.
The 82mm is supposed to give more life as we all know the chain stretch on these MINI's. The 82mm tensioner is the final 5th Gen redesigned tensioner and is much smoother and quieter.
Tensioner here - Timing Chain Tensioner with Seal Ring 11317607551
Old 09-29-2016, 08:29 AM
