Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Is the seal that you mention replacing the output seal? This was not included in the parts list?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Drive Axle Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 10-09-2016, 08:48 AM
Nick at Pelican Parts's Avatar
The seal mentioned in the procedure is the driveshaft output seal.
Give The Pelican Parts parts specialists a call at 1-888-280-7799. They can figure out what part or repair kit you need.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
Shaft seals here: Mini Cooper, Cooper S, and Clubman (R55/R56/R57) - Axles, Bearings & Differential - Page 1.
Old 10-10-2016, 09:45 AM
