Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
flathead45 (guest)
Guest
Posts: n/a
Hi,
Mini N14 2007 / 140kkm
Engine throws out faulty Throttle position sensor no other, lacks power in lower revs. Starts up without problems, in lower RPM range engine is noisy, exceed 2-3k rmp - drives smooth. Possible also VANOS or would it throw error code ?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 VANOS Solenoid Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 10-09-2016, 08:51 AM
Nick at Pelican Parts's Avatar
it would likely set code if VAnOS were an issue. I would inspect the throttle housing and connector.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
Curious about a few things: What would you describe the noise sounds like? When was the last time the timing chain and tensioner was replaced? What is the exact P code that is being thrown? When was the last time you did a carbon clean up?
MINI Cooper R56 Turbocharged Engine Carbon Cleaning (2007-2011) | Pelican Parts DIY Maintenance Article
Old 10-10-2016, 09:25 AM
