Guest
Posts: n/a
Hi,
Mini N14 2007 / 140kkm Engine throws out faulty Throttle position sensor no other, lacks power in lower revs. Starts up without problems, in lower RPM range engine is noisy, exceed 2-3k rmp - drives smooth. Possible also VANOS or would it throw error code ? __________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 VANOS Solenoid Replacement (2007-2011) | Pelican Parts DIY Maintenance Article |
it would likely set code if VAnOS were an issue. I would inspect the throttle housing and connector.
- Nick |
Administrator
Curious about a few things: What would you describe the noise sounds like? When was the last time the timing chain and tensioner was replaced? What is the exact P code that is being thrown? When was the last time you did a carbon clean up?
MINI Cooper R56 Turbocharged Engine Carbon Cleaning (2007-2011) | Pelican Parts DIY Maintenance Article |
Thread Tools | |
Rate This Thread | |
