Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Please help
On a Mini Cooper 2009 r56 engine. Should their be slack in the oil pump drive chain located behind lower sprocket of timing chain. I'm in the process of replacing the timing chain and noticed that the oil pump chain has approximately 3/8" to 1/2" slack / deflection in it, is this normal?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Turbocharged Engine Timing Chain Guides Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 11-04-2016, 11:25 AM
Nick at Pelican Parts's Avatar
it shouldn't have a ton of slack, but won't be tight like a timing chain. Check if the gears are worn.
- Nick
