Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Buzzard 95 (guest)
Guest
Posts: n/a
I recently replaced my water pump on my 2004 R50, and after a few months, noticed small pools of coolant after driving. I think I have isolated the problem to the hose between the block & the pump. Since this hose is a bear to get at, can I use a different type of hose clamp or some type of sealant when I replace the hose?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Radiator, Thermostat and Hose Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Old 12-13-2016, 10:29 AM
Nick at Pelican Parts's Avatar
Very common for the hose fitting plate and block-off plates on the block to leak. BUT that hose is definitely leaking as well. new hose clamps at the minimum. No sealant.
Give The Pelican Parts parts specialists a call at 1-888-280-7799. They can figure out what part or repair kit you need.
- Nick
