Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Harvey (guest)
Guest
Posts: n/a
My 2007 mini s runs strong and idles smoothly. No obvious codes. BUT- it is going through a quart every 150 miles. There are no evident oil leaks. I have not yet done a compression check. Could this be the turbo oil seal? If so, how do I diagnose. Thanks - your write-ups are world class!
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Turbocharger Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 12-13-2016, 10:40 AM
Nick at Pelican Parts's Avatar
Remove the turbo ducts and inspect the hoses for excessive oil. Some oil residue is normal, look for puddles.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
Check your PCV. They're known to cause issues as engine oil consumption increases significantly if the crankcase ventilation system is defective. Read our oil consumption article here: MINI Cooper R56 Oil Consumption Diagnosis (2007-2011) | Pelican Parts DIY Maintenance Article. To check the PCV, disconnect the PCV hose on the valve cover and see if its heavily coated with oil. Definitely perform a compression and leak down test.
Old 12-22-2016, 09:54 AM
