Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
delta86d (guest)
Guest
Posts: n/a
Recently replaced my thermostat housing. After driving around 20 miles, my CEL came On, p0597, p0173b,p122b. There are no leaks so I just checked the connector going to the ECT sensor and it's just 3.3V. Do you think there is a problem with my ECU? Where would you start if were to troubleshoot this problem? Thanks in advance.
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Coolant Temperature and Oil Pressure Sensor Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 12-21-2016, 09:17 AM
Nick at Pelican Parts's Avatar
The harness may be damaged. I would check voltage at the DME to confirm it is low as well.
- Nick
