Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Gem (guest)
Guest
Posts: n/a
Hi Nick i have a 2845 code on 2007 n12 twin vanos replace chain kit still the same do you think vanos is faulty thanks.
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 VANOS Solenoid Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 01-18-2017, 06:44 AM
Nick at Pelican Parts's Avatar
Yes, if the timing components and solenoids are OK, the VANOS actuator could be at fault. Before replacing, double check camshaft timing.
- Nick
