Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
catsarse (guest)
Guest
Posts: n/a
hi i have a 2007 cooper auto, it starts fine and runs for about ten seconds the starts to hunt and eventually cuts out at stand still.
you can drive the car for about 100 yeards then engine power dies off and you have to restart once again the same thing will happen after another 100 yards.
can you please give me an idea whats wrong.
many thanks
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Fuel Pump and Filter Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Old 01-25-2017, 12:42 PM
Nick at Pelican Parts's Avatar
Could be an issue with the fuel pump. I would perform a fuel delivery system test. Check fuel pressure, volume and quality.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
Any fault codes present in the system? It's a Cooper non-s correct? Does sound fueling related.
Old 01-26-2017, 09:08 AM
