Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
coopercito67 (guest)
Guest
Posts: n/a
hi Nick, my question is the problem on power steering on a 2006 mini cooper is the motor or the pump and is posible to repair it or changing the motor the problem could be fix?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Power Steering Pump Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Old 01-25-2017, 12:43 PM
Nick at Pelican Parts's Avatar
There are companies that repair them. That is your only option other than replacing it.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
The pump itself fails/leaks. Also, inspect the power steering pump lines as those commonly leak as well and could be the source of your leak if you are only seeing a fluid leak and no other symptoms. Some drivetrain shops could do rebuilds. Google and see what is in your area.
We do have rebuilt and new units here: 2006 Mini Cooper Base Hatchback - Steering System - Page 1.
Old 01-26-2017, 09:07 AM
