Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Sbrow5322 (guest)
Guest
Posts: n/a
R55 Clutch Replacing
Hi would this write up work for a 2008 Mini Cooper Clubman ? Thanks
This post was auto-generated based upon a question asked on our tech article page here: Mini R56 Clutch Replacement | R56 Cooper (2007-2013) | Pelican Parts DIY Maintenance Article
Old 01-25-2017, 12:45 PM
Nick at Pelican Parts's Avatar
No. We don't currently have that tech article. If we get a chance to perform the procedure, we will be sure to document it.
I would grab a repair manual. It will have the procedure, special tools and torque specs.
Give our parts specialists a call at 1-888-280-7799.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
I would take a peek at RealOEM.com - Select Your BMW Model.
You can use the article as a reference for your R55 and then I'd also purchase the Bentley Manual for additional help here: 2008 Mini Cooper Clubman Wagon - Books & Technical Documentation - Page 1
Old 01-26-2017, 08:57 AM
