Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Daryl (guest)
Guest
Posts: n/a
hi, i was also getting the PO237 code. I replaced the boost pressure sensor and it did not go away. I tested the harness with a test light and the car off. The only wire that goes to ground is the white one and I think it is supposed to do that. Any suggestions?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Turbocharged Engine Pressure Sensor Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 01-25-2017, 12:48 PM
Nick at Pelican Parts's Avatar
I don;t know what a test light will do. The actual circuit voltage is needed for testing, using a DVOM.
- Nick
