Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
James (guest)
Guest
Posts: n/a
2009 mini 1.4 runs good when under load you can here a chatter and the the vehicle smokes a lot?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 VANOS Solenoid Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 02-07-2017, 11:13 AM
Check your oil level ASAP!!! Sounds like a low oil level issue.
- Casey
Administrator
Luccia at Pelican Parts's Avatar
You may have already done damage. The timing guides wear from lack of lubrication and running low on engine oil. This can cause timing chain rattle at start up, noise when running and worse-case scenario a jumped timing engine.
More info here: MINI Cooper R56 Turbocharged Engine Timing Chain Guides Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 02-08-2017, 07:43 AM
