Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Schonedog (guest)
Guest
Posts: n/a
Hello, Please help. My daughter has a 2003 mini cooper R50. The shift cables are bad and need replaced. I was told that there are two types of shifters used in the car and that the cables I need are based on the shifter housing. The housing either has three grooves or is smooth. There is no way to view the external portion of the shift housing without removal. Is there a way to determine which housing is used and what cables are required without removing the housing?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Shift Cable Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Old 02-10-2017, 10:37 AM
See answer to other question.
- Casey
Schonedog (guest)
Guest
Posts: n/a
Hello, I found that the shift is version 'A' shifter with 3 ridgeshow do I go about ordering the correct cables?
Old 02-10-2017, 10:41 AM
25-11-7-515-455-BOE
25-11-7-515-456-BOE
- Casey
