Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Chadder (guest)
Guest
Posts: n/a
I am experiencing similar problems to a previous thread MCS od JCW, code 2C57. I've replaced the diverter valve to no avail. The thread does not come to a conclusion. I've applied vacuum to my wastegate and it functions smoothly. Is my next move to check the wastegate? Is there anything aftermarket to cure this? 2012 N18 with 85K.
This post was auto-generated based upon a question asked on our tech article page here: Mini R56 Testing the Engine Turbocharger Wastegate | R56 Cooper S Hatchback (2007-2013), R56 Cooper JCW Hatchback (2009-2013) | Pelican Parts DIY Maintenance Article
Old 02-13-2017, 10:58 AM
I have seen faulty turbocharger cause that fault if the diverter is OK.
- Casey
Administrator
Luccia at Pelican Parts's Avatar
Is this the thread you're talking about? http://forums.pelicanparts.com/bmw-mini/927923-fault-code-2c57.html
Did you check the Pressure Converter?
Yes, test the wastegate using this article: Mini R56 Testing the Engine Turbocharger Wastegate | Pelican Parts DIY Maintenance Article.
Old 02-14-2017, 07:29 AM
