Guest
Posts: n/a
I am experiencing similar problems to a previous thread MCS od JCW, code 2C57. I've replaced the diverter valve to no avail. The thread does not come to a conclusion. I've applied vacuum to my wastegate and it functions smoothly. Is my next move to check the wastegate? Is there anything aftermarket to cure this? 2012 N18 with 85K.
__________________ This post was auto-generated based upon a question asked on our tech article page here: Mini R56 Testing the Engine Turbocharger Wastegate | R56 Cooper S Hatchback (2007-2013), R56 Cooper JCW Hatchback (2009-2013) | Pelican Parts DIY Maintenance Article |
I have seen faulty turbocharger cause that fault if the diverter is OK.
- Casey |
Administrator
Is this the thread you're talking about? http://forums.pelicanparts.com/bmw-mini/927923-fault-code-2c57.html
Did you check the Pressure Converter? Yes, test the wastegate using this article: Mini R56 Testing the Engine Turbocharger Wastegate | Pelican Parts DIY Maintenance Article. |
Thread Tools | |
Rate This Thread | |
