Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Blade (guest)
Guest
Posts: n/a
Ive been told I need to replace the Vaulve cover because of high pressure inside the crank case. Is there a way to clean the crank case filter.
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Valve Cover Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 02-20-2017, 08:58 AM
You can try to run some cleaner through the PCV ports but I think ultimately you'll need the new valve cover sooner or later.
- Casey
Administrator
Luccia at Pelican Parts's Avatar
If the valve cover is cracked or the PCV is working incorrectly you need to replace the valve cover. MINI updated it and depending on if yours has ever been replaced, here is the updated version: Mini Cooper, Cooper S, and Clubman (R55/R56/R57) - Cylinder Head & Valvetrain - Page 1
Old 02-21-2017, 08:29 AM
