Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Borracho bean (guest)
Guest
Posts: n/a
Wooooo that was brutal, I just took off the thermostat and I found it funny that there was no metal pin connecting the water pipe and thermostat. It was glued together! So yes as I pulled on the connection my water pipe came out, and I'm glad it did. The end of it that connects to the water pump was completely destroyed, like crumble in my hands destroyed. So now I await the water pipe and a new pin. Thanks for the help so far!
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Turbocharged Engine Thermostat Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 03-15-2017, 06:26 AM
Nick at Pelican Parts's Avatar
WHOA. Glued in - NOT GOOD.
Glad you got it worked out.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
It's somewhat common for the ends to get melted/brittle and fall a part. That piece sees a lot of heat and should be replaced anytime you replace the water pump or thermostat. Yes, make sure just to use the clip when installing it back in. Good luck!
Mini Cooper, Cooper S, and Clubman (R55/R56/R57) - Water Pump, Thermostat & Hoses - Page 2
Old 03-15-2017, 10:43 AM
