Guest
Posts: n/a
when we are changing the clutch and installing a quaife differential, can we just fill up the case with transmission fluid before we put it back on the car?
__________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Manual Transmission and Differential Fluid Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article |
Sure, just double check the fluid level again after it is bolted up.
- Casey |
Thread Tools | |
Rate This Thread | |
