Guest
Posts: n/a
07 Cooper 3000 rpm rattle like cards on bike spokes. Rough idle at 1000 rpm check engine light use Techron & shell 93 100005 miles harmonic balancer ??
__________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Crankshaft Pulley Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article |
Possible timing chain issue.
- Nick |
Administrator
Is it a Cooper Base or Cooper S? First things first, plug into your OBDII port and check what fault code is triggering your CEL. Check your oil level - is it low?
