Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Sandra (guest)
Guest
Posts: n/a
Hi, diagnostics machine says the cam belt sensors need replacing. Should they both be fine at the same time?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Camshaft Sensor Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 04-19-2017, 07:14 AM
Nick at Pelican Parts's Avatar
I would replace as a set. When one goes bad, the other usually isn't far behind.
- Nick
