Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Tony (guest)
Guest
Posts: n/a
Great article. Thank you. I replaced the camshaft position sensor, great service from you guys btw, and cleared the codes, but the check engine light came back. I just finished cleaning the solenoid and the car is running much better. Do I need to clear the code again, or will it clear itself if the problem is fixed?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 VANOS Solenoid Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 04-20-2017, 09:05 AM
Nick at Pelican Parts's Avatar
the code will go away once three consecutive good drive cycles occur. Otherwise you'll have to clear it.
- Nick
