Guest
Posts: n/a
Hi, I have a 2006 Mini Cooper S, and the battery is completely shot and needs to be replaced. How do I know if the computer will need to be reset after replacing the battery?
__________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Battery Replacement and Battery Tender Installation (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article |
if the negative terminal has electronics on it, you will have to register the new battery.
- Nick |
Administrator
I don't believe the R53 came equiped with the IBS unit. You can always check by looking at the negative battery terminal. The R56 is what came with or even with out the IBS modules. Info on them here: MINI Cooper R56 Battery and Connection Notes Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
