Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
B (guest)
Guest
Posts: n/a
Hi.. I have a Mini Cooper 1.6 petrol on a2098.. it has 85k miles and the engine light was in when I bought the car.. I was advised it may be the cam timing so had a new chain and tentioners put in.. the engine light is still on.. the code shown on the machine is p2968.. the intake cam sensor.. I replaced this but still no luck.. have you any idea what it may be.. thank you for your time
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Camshaft Sensor Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 05-09-2017, 05:56 AM
Nick at Pelican Parts's Avatar
If any of the faults 2968, 296B, 2982, or 2983 are stored, follow the procedure below:
Replace the camshaft sensor (refer to the EPC) and the camshaft connector using P/N 12 52 7 590 939.
Give The Pelican Parts parts specialists a call at 1-888-280-7799. They can figure out what part or repair kit you need.
- Nick
