Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
CENLA Mini (guest)
Guest
Posts: n/a
I know you can replace the sensors but can replace the wire assembly they plug into? My driver side plug housing broke when I replaced it last time and now I need to replace them again...would like to find a replacement if possible. Sensor Mfg Part # is 34356778175...this is not what I need...I need the wiring harness this plugs into.
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Brake Pad Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Old 05-17-2017, 07:09 AM
Nick at Pelican Parts's Avatar
Yes, you will have to repair or replace the wiring harness. Give The Pelican Parts parts specialists a call at 1-888-280-7799. They can figure out what part or repair kit you need.
- Nick
