Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
JaxPops (guest)
Guest
Posts: n/a
had no problem with the T50 bolts. Used a pry bar between two lug bolts put back on the hub across from each other to use for leverage. Also used pb blaster to help loosen all bolts.
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Brake Disc Replacement (R50/R52/R53 2001-2006) | Pelican Parts DIY Maintenance Article
Old 05-17-2017, 07:09 AM
Nick at Pelican Parts's Avatar
Thanks for the additional info and feedback. We appreciate it.
- Nick
