Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
KH (guest)
Guest
Posts: n/a
I installed new wheels and reset TPMS as described above. The system went to 'active' state, but about a day later, every time I start the car it shows the Tire warning icon on the tachometer when shutting off engine, and a warning triangle next to the trip meter at all times, but the TPMS light on the speedometer remains off. Anybody know what's wrong?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Tire Pressure Monitoring (2007-2011) | Pelican Parts DIY Maintenance Article
Old 06-26-2017, 11:26 AM
Nick at Pelican Parts's Avatar
Possible faulty sensor. You will need to check fault codes to see which sensor is reading low or offline.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
Yes, plug in and read what fault codes are present in the system. If you don't have a scan tool we have them here: http://forums.pelicanparts.com/bmw-mini/961160-bavarian-technic-diagnostic-tools-now-available.html
Old 06-28-2017, 09:07 AM
