R56 Where is TPMS antenna located?
I have a 2008 Cooper S that is showing 'inactive' for the TPMS. I've used an Autel tool to activate all four sensors and they read OK. I don't see any codes, but not sure my reader would see TPMS codes. I'm thinking about replacing the central antenna not the per wheel transmitter located in each wheel well. Others have reported failures of this part. I can't however find where it is located. Any clues?
__________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Tire Pressure Monitoring (2007-2011) | Pelican Parts DIY Maintenance Article
Scott Wilburn 1988 911 Carrera 3.4 L 1998 M3 1984 308 QV |
Best bet is to read fault codes. You could have a faulty sensor in a wheel. A MINI scan tool should show all the sensors as well as display faults.
- Nick |
Since my first post, I obtained a code reader that can read Mini codes. It gives me 6053, which is the code for a faulty antenna. I've ordered a new one from Pelican, but still can't find any information on where it is located.
Administrator
This info may help you:
![]() If you don't find it, go back to the article you left a comment on (linked in your first post) and post another comment on it. Nick will have input for you as well. Good luck. |
Thread Tools | |
Rate This Thread | |
