Guest
Posts: n/a
I'm about to change the timing chain in my 2009 Cooper S. I recently change the oil and spark plugs in an effort to fix a misfiring issue and was wondering if I would need to replace the oil again. The car has maybe ran a minute with the new oil in it.
__________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Turbocharged Engine Timing Chain Guides Replacement (2007-2011) | Pelican Parts DIY Maintenance Article |
As long as you don't get debris in to the engine, you will have to only check and top up the oil as needed.
- Nick |
