LinkBack | Thread Tools | Rate Thread |
Guest
Posts: n/a
I have a 2007 mini cooper s it started surging and running bad after i had the thermostat housing changed now it won't idle and is running like crap what could be the problem any help would be appreciated
__________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Coolant Temperature and Oil Pressure Sensor Replacement (2007-2011) | Pelican Parts DIY Maintenance Article |
I would start by checking the DME for fault codes. If the system is not working properly, a fault code will be set. This will be your best bet when diagnosing.
- Nick |
Administrator
Make sure you don't have any vacuum leaks. How many miles are on your R56?
