Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
justin (guest)
Guest
Posts: n/a
i changed the plastic housing for the sensor to the vanos solenoid. pull the wiring out from the old and stuck it in the new. After got the error code p0013. looked at the wiring. no marks or abrasions. It does look a bit stretched as i had to pull hard to release it from the old plastic housing. Any thoughts on why Im getting the p0013 code?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 VANOS Solenoid Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 08-12-2017, 06:32 AM
Nick at Pelican Parts's Avatar
Possible you damaged the wiring or connector.
- Nick
