Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
mininic (guest)
Guest
Posts: n/a
My 2008 standard mini cooling fan does not run at idle and ac is blowing warm. I checked the fuses/relays and it shows spots for two relays and there is only one plugged into the the low speed. There is nothing plugged into the high speed spot.
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Cooling Fan Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 08-18-2017, 06:30 AM
Nick at Pelican Parts's Avatar
I would double check that your vehicle has two relays and replace the missing one. Give The Pelican Parts parts specialists a call at 1-888-280-7799. They can figure out what part or repair kit you need.
- Nick
