Guest
Posts: n/a
Which part would be suspect is only the satellite is not functioning? Constantly says "acquiring..." but will sometimes pick up while on a high bridge or overpass.
Also, can you give more guidance on "MINI scan tool"? Which models allow module programming vs. just reading/resetting DTCs? __________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Radio Antenna Replacement (2007-2011) | Pelican Parts DIY Maintenance Article |
The sat antenna is on the roof, part of the antenna base. Give The Pelican Parts parts specialists a call at 1-888-280-7799. They can figure out what part or repair kit you need.
- Nick |
