Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
JR (guest)
Guest
Posts: n/a
I have a 2008 Mini R56. The limp mode light will come on so there is no turbo boost, but there are no codes or other warning lights on. What could be causing this? This is my first Turbo vehicle.
P.S. Your tech articles are great. I have used the BMW section for many things
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Turbocharged Engine Pressure Sensor Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 08-30-2017, 09:52 AM
Nick at Pelican Parts's Avatar
If the light is on, fault codes have to be stored. Check for pending as well. I would assume there is a boost deviation happening.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
Pull the codes. If you need a code reader: http://forums.pelicanparts.com/bmw-mini/961160-bavarian-technic-diagnostic-tools-your-mini.html.
Old 09-08-2017, 09:35 AM
