Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Preteesh Leo. (guest)
Guest
Posts: n/a
Hello,
Could you add the details on how to change the oil filter housing gasket on a 2006 R56 base. I've ordered the gasket and hoping to do it myself.
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Turbocharged Engine Oil Cooler and Filter Housing Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 08-30-2017, 09:49 AM
Nick at Pelican Parts's Avatar
We don't currently have that tech article. If we get a chance to perform the procedure, we will be sure to document it.
I would suggest you grab a repair manual, you should own one. It will have the procedure, special tools and torque specs.
Give our parts specialists a call at 1-888-280-7799.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
If you can document the procedure yourself we will give you 10% off your next parts order with us. Details here: Enthusiast Tech Article Submissions - Pelican Parts
Old 09-08-2017, 09:04 AM
