Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Peter 86 (guest)
Guest
Posts: n/a
My Radiator fan stop working, i disconnected the temp sensor and the fan came to live. I thougth that my temp sensor was not eorking and repalce it. After connecting all the wires and start the engine, let it warm up and turned on the ac, and the fan did not start. Does it means i need to change the thermostat?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Coolant Temperature and Oil Pressure Sensor Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 09-08-2017, 06:24 AM
Nick at Pelican Parts's Avatar
The low speed portion of fan may be faulty. With no coolant temp, high speed is activated.
- Nick
