Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
holmsey (guest)
Guest
Posts: n/a
hi my daughter has a R56 N12 mini and we changed the timing chain and guides, the Vanos solenoids and one of the cam sensors. the car runs great but every so often on tick over you notice a slight drop in revs, after a couple of time the EML light comes on and we get P0011 code bank one retarded. Any ideas..could it be the actuator...
thanks
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Valvetronic Faults (2007-2011) | Pelican Parts DIY Maintenance Article
Old 09-29-2017, 07:54 AM
Nick at Pelican Parts's Avatar
It could be the camshaft actuator. It could be jamming. Confirm mechanical timing is OK. If so, the actuator may be at fault.
- Nick
