Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Bo (guest)
Guest
Posts: n/a
I have a 2006 MC S 6 speed auto with shifting issues.. Trans works fine when cold but when it warms up it throws hard shifts into 2nd and then 3rd, revving high and banging onto gear. Also bangs on down shift when slowing down and from a stop while backing out of a parking spot.
It threw a EP code and went into limp mode the other day, cleared that code and its back running.
Code P2720 pressure control solenoid D -control circuit low
Code P0700 Trans control system -malfunction lamp indicator
I had previously done a fluid dilution , refilling up thru the pipe in hopes of avoiding pan removal.
Is the pressure sensor available ? Has hat fixed this issue in similar cars?
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper Automatic Transmission Fluid Change (R50/R52/R53/R56/R57 2001-2015) | Pelican Parts DIY Maintenance Article
Old 10-29-2017, 05:44 AM
Nick at Pelican Parts's Avatar
Likely being caused by low fluid or worn seals / clutches. You can monitor pressure adaptation to see if it is too high, if so, the trans is worn out.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
Check the fluid level, if it's low it will cause all sorts of shifting issues. When was the last time you did a flush, not that this will solve the issue, but a place to check before replacing the transmission.
Old 11-03-2017, 07:50 AM
