Guest
Posts: n/a
2010 Mini Cooper Clubman S - How do you determine if the problem is the fuel pump in the gas tank, or the High Pressure Fuel Pump, driven by the Intake camshaft? Thanks.
__________________ This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Fuel Pump Replacement (2007-2011) | Pelican Parts DIY Maintenance Article |
By testing the low pressure fuel delivery system using a gauge, then testing the high pressure system using a scan tool like Autologic AssistPlus.
- Nick |
Administrator
To test the HPFP, look at figure #10 in this article here: MINI Cooper R56 Fuel Pump Testing (2007-2011) | Pelican Parts DIY Maintenance Article
