Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
keawe puhi (guest)
Guest
Posts: n/a
would a dtml cause low fuel pressure change sending unit for fuel filter car started ran then put into drive car dies when bypassing the hose to vapor canister and starting fluid car runs. I have low fuel pressure any help car is a 06 mini cooper non supercharge
This post was auto-generated based upon a question asked on our tech article page here: MINI Cooper R56 Charcoal Canister Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
Old 10-29-2017, 07:05 AM
Nick at Pelican Parts's Avatar
No it would not. Likely a faulty fuel pump or voltage supply to pump.
- Nick
Administrator
Luccia at Pelican Parts's Avatar
If you figure out that it's your fuel pump we have them here: Mini Cooper, Cooper S, and Clubman (R55/R56/R57) - Fuel System - Page 2.
Old 11-17-2017, 10:29 AM
