Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Hump? What hump?
EugeneTheBeast's Avatar
Looking at non runner Base Mini 2003
Hello all,
I'm looking at a non running 2003 base model Mini that for sale locally. The owner replaced to fuel pump and it's getting gas up to the rail but it still won't start/run. He was able to get it run run briefly with starting fluid, so I'm suspecting that something is causing the injectors not to pulse. I don't have code reader yet, so what would be the most likely suspects?
I can no longer sit back and allow Communist infiltration, Communist indoctrination, Communist subversion and the international Communist conspiracy to sap and impurify all of our precious bodily fluids!
Old 11-28-2017, 08:06 AM
Administrator
Luccia at Pelican Parts's Avatar
Hello! Is it a Cooper or Cooper S? You need to plug into the DME and check for faults. There can be many reasons why it will not start. Codes will be your fastest and best bet when diagnosing the issue. Once you plug in, report back with the codes.
Old 12-29-2017, 01:12 PM
