dan79brooklyn's Avatar
The Turtle Wax kit is supposed to be a good. Less than $10. Includes a protective sealer.
https://www.walmart.com/ip/Turtle-Wax-T240KT-Headlight-Lens-Restorer-Kit/16927980?u1=-%20&oid=589058.1&wmlspartner=xzXATABADTI&sourceid=35822976070166944501&affillinktype=10&veh=aff
I have been using a different headlight polishing kit. It gets the lenses clear but they still look a little yellow (Benz w210).
Old 07-16-2018, 03:44 AM
Send a message via AIM to fintstone
Mine were yellow until I wet sanded first. Now they are perfect.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 07-16-2018, 05:15 AM
sugarwood's Avatar
Originally Posted by fintstone View Post
Don't even need an orbital. Easy to do by hand.
The correct way is to wet sand down to 2500 grit, and then you absolutely need an orbital.
Or 20 years of hand polishing. Nothing matches the RPMs of an orbital.
1986 Bosch Icon Wipers coupe.
Old 07-16-2018, 05:50 AM
Originally Posted by sugarwood View Post
If you wet sand down to 2500 grit, you absolutely need an orbital.
Takes me less than a minute by hand (after wet sanding with 1600 paper)...and would certainly not waste my time wet sanding with 2500 grit paper (might as well use notebook paper. Maybe I am special.
Old 07-16-2018, 05:53 AM
Done this on many cars. The best kit out there is one that's made by 3M. Multi stage sanding by hand or drill. The new kits actually have a clear to apply to the lens after the final wet sand. Its awesome.
Old 07-16-2018, 07:54 AM
vash's Avatar
done it twice. turned them damn near into diamonds. super shiny, super clear.
i even use some UV coating. best i got was a year of bliss. i think they yellow/haze worse than when i started.
i drive a tacoma, so i'm lucky there is a huge group of folks modifying them. i found factory take-offs for $100. they are in such good shape and i am on 2 years of bliss.
poof! gone
Old 07-16-2018, 01:22 PM
I see you
flatbutt's Avatar
oh! oh! oh! Mr Kotter! Mr Kotter! Please do tell.
Old 07-16-2018, 03:36 PM
Don Ro's Avatar
Just watched this.
Don
"Fully integrated people, in their transparency, tend to not be subject to mechanisms of defense, disguise, deceit, and fraudulence."
- - Don R. 1994, an excerpt from My Ass From a Hole in the Ground - A Comparative View
Old 07-22-2018, 02:30 PM
Almost Banned Once
sc_rufctr's Avatar
I fixed my daughters car a few years ago. The word got around and I've now done more than 20 cars! (all for free)
- Peter
Old 07-22-2018, 03:55 PM
Don Ro's Avatar
Spanking clean. Did you use the last method that's in the vid I posted?
What sequence/method did you use?
Don
Old 07-22-2018, 03:58 PM
Almost Banned Once
sc_rufctr's Avatar
I use pro paint cutting compound and a lambs wool bonnet. They last about 18 months before they need redoing.
IME the coatings/lacquer are a waste of time. Halogen head lights get very hot and I've seen some coating go yellow.
- Peter
Old 07-22-2018, 04:05 PM
Leadfoot Geezer
rcooled's Avatar
Originally Posted by HardDrive View Post
25 cents worth of toothpaste, and a little elbow grease...
I once used toothpaste to remove paint residue from a rental car's fender after I brushed against a painted pole in a parking garage. Had a plane to catch and no FLAPS nearby. There was no permanent damage to the paint and the toothpaste did a great job of removing the telltale paint streaks.
'13 BMW 335i coupe - current DD
Old 07-22-2018, 05:04 PM
