Yep, that's how my home made one is supposed to work but I haven't been able to get it to ignite so far. As for ground squirrels, I take care of them with my air rifle. I had dozens of them all over the place when I moved in ten years ago. A friend and I shot maybe fifteen of them one afternoon. After that I would plink them as time went on, and now I only have maybe one to three new ones each year. The new ones seem to know about me, because they hi tail it at first sight.
Marv Evans
'69 911E
Old 04-09-2019, 03:04 PM
bmcuscgr94's Avatar
Originally Posted by Evans, Marv View Post
Thanks. The propane side must have a nozzle with a propane orifice on the Rodinator you used. Usually the oxygen supply side, especially if it's compressed air, is open several times the amount of the propane side.
Your are correct, my memory failed me. From the instructions: open oxygen control knob one and one half turns from full closed position. Open propane control knob 1/8 to 1/4 turn from the full closed position. Injection time is 30 to 90 seconds depending upon soil type for ground squirrels. The mixture goal is less than 2% LPG and 98% compressed oxygen. The manual says the concussive shockwave is over 10,000 psi in the tunnel system.
Old 04-09-2019, 06:22 PM
Great info, thanks. I'll use the propane/oxygen ratio range when I try it this summer.
Marv Evans
'69 911E
Old 04-09-2019, 08:46 PM
"I smell varmint poontang" !
Old 04-10-2019, 02:36 AM
