Unregistered
sammyg2's Avatar
If you plant bamboo it will get rid of the Johnson grass
Old 08-13-2018, 03:13 PM
Use a selective herbicide with 2,4-D in it.....follow the directions....may need a couple applications a couple weeks apart. You should see browning within' the first week and can re-spray as needed 14 days after the first application.
Weed-B-Gon by Ortho is one that might work.
Try in a small area first before doing any large areas!
Old 08-13-2018, 03:19 PM
Information Overloader
Timely thread. Something is invading the lawns around here where I am just south of permafrost zone. The thin stuff is the normal mix of perennial rye, Kentucky blue and red fescue. The thick bladed, lighter green stuff is taking over!
Old 08-13-2018, 04:51 PM
A wider shot here. I'm thinking this is some kind of invasive non-native turfgrass most likely from Asia.
Old 08-13-2018, 04:55 PM
wdfifteen's Avatar
Looks like common crab grass to me.
Old 08-13-2018, 05:24 PM
Unregistered
sammyg2's Avatar
This goes against every thread of my being, but have you guys ever considered hiring one of those professional lawn care gurus? The guy who come by once a week or so and spray the magic green stuff?
I've considered it before, only for a few months at a time to make stuff look really nice.
unfortunately the watering laws have screwed up what was once a pretty nice yard.
Old 08-13-2018, 07:04 PM
Jolly Amaranto's Avatar
Looks like Johnson Grass to me. St. Augustine has a rounded point blade that come off of the runners in a flat orientation.
It use to be in Houston they called Johnson Grass "Dallas Grass" while in Dallas they called it "Houston Grass."
Old 08-13-2018, 07:36 PM
A930Rocket's Avatar
+1 it’s not Bermuda.
Looks like crabgrass to me.
Originally Posted by wswartzwel View Post
Bermuda grass has a narrow blade... that isn't Bermuda...Bermuda makes a nice lawn..... What you have is Johnson Grass. https://www.google.com/search?q=johnsongrass&client=safari&rls=en&source=lnms&tbm=isch&sa=X&ved=0ahUKEwiC84ad6ercAhURC6wKHbz_DF0Q_AUICigB&biw=1363&bih=607
Round up will kill it.
Old 08-13-2018, 07:48 PM
Hey....you found MY quarter! I just know it ain't fescue or Ky. bluegrass....or St A . People in Fl are funny....spend thousands for sod, more for religious watering, pest control, etc. And they want to call it grass too !
Old 08-14-2018, 02:16 AM
(the shotguns)
berettafan's Avatar
its crabgrass where I'm from. you kill it with money.
we have a lawn guy who spreads stuff a couple times a year. will take about 1 or 2 seasons to get real progress against that stuff as I'm told it has to be prevented, not killed. my neighbor uses the same lawn guy and he only does his front. yard. our back yards are remarkably different.
Old 08-14-2018, 03:49 AM
Alii&Maui
Jesset100's Avatar
Thanks guys for all your input. Yea this one is a real monster to get rid of. I believe it is St. Augustine grass as it looks exactly like the pictures in Google images when searching St. Augustine. I’ve used Ortho weed be gone and didn’t phase it one bit. Right now the herbicide of choice is Drive XLR8 made by BASF. I’m mixing 3 tablespoons of Drive with one gallon of water and applied it twice in two weeks although the directions say reapply 14 days after first application. While Drive is killing crabgrass is doesn’t harm St. Augustine in any way.
1982 SC Coupe
SCWDP#0087
KCSSL#0082
Old 08-20-2018, 07:42 AM
hardflex's Avatar
I want to say that's not St Augustine, it's Dallas Grass. There are Youtube vids on how to kill it.
You can kill St Augustine with just a broad leaf type weed killer. No need for roundup, especially if you want something else to grow there. My neighbor laid his whole yard with st augustine sod and then killed it by too aggressively putting on a weed and feed.
72 914 2056: 74 9146 2.2: 76 914 2.0
Old 08-20-2018, 08:51 AM
No, this is NOT St. Augustine.
It is quite different from this which is.
Old 08-20-2018, 11:24 AM
I see you
flatbutt's Avatar
t.
here too.
Old 08-20-2018, 11:33 AM
brainz01's Avatar
I have a confession to make: I bought some Roundup grass and weed killer this weekend and sprayed it selectively around the yard. I mostly used it on a bunch of random weeds growing around my setbacks, but did also spray some on some "St Augustine" that was sending runners into places I didn't want it. I'll report back with whether it made any difference.
And I wore gloves.
Old 08-20-2018, 12:20 PM
Alii&Maui
Jesset100's Avatar
Originally Posted by cabmando View Post
Sheesh! 19 posts and no one got it right!!
You're on to something. After overthinking about what herbicide to use i've decided to go the burn route. Just bought one of these from Amazon
So sometime this weekend i'll give it a try. I did read that it's not a one and done kind of solution but I have to repeat the burn until the root is starved and finally die. Funny thing is most of the problem is in my neighbors yard. What I got my neighbor will get and what my neighbor got I'll get.
Wish me luck.
1982 SC Coupe
SCWDP#0087
KCSSL#0082
Old 08-20-2018, 01:52 PM
Why not go with something like this? It will allow any good grass to continue growing..instead of having scorched earth.
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 08-20-2018, 02:51 PM
