Alii&Maui
Jesset100's Avatar
What is this and how do I kill it.
This stuff is taking over my yard as well as my neighbors yard. We didn't have this last year but what we did have is "normal crabgrass" problems. I'm using Drive XLR8 to kill crabgrass but this weed/grass laughs XLR8 off.
One lawn care professional said it's Timothy grass but looking it up on the net it's totally different. Any help with a description and treatment I'd appreciate.
1982 SC Coupe
SCWDP#0087
KCSSL#0082
Old 08-13-2018, 10:25 AM
brainz01's Avatar
That looks like St Augustine. It's what passes for grass in Houston. Our lawns are made of it. It's a creeping grass (versus seed). Thick bladed, heat resistant, and tough.
You'll need to rip it out if that's not what you want as it will take over.
Old 08-13-2018, 10:29 AM
David's Avatar
In Houston we call it grass. We can't seem to get anything else to grow
Old 08-13-2018, 10:50 AM
First you need to find out if it's an annual or a perennial...
It looks like what we call annual crab grass, which means you deal with it next with crab-grass spray.
Old 08-13-2018, 10:55 AM
Cars & Coffee Killer
legion's Avatar
I have something like that in my yard, but we have freezing winters here and I thought St. Augustine wouldn't survive that.
I've tried to pull it and spray it. Nothing works. Next up: roundup.
5 liters of VVT fury now
-Chris
Old 08-13-2018, 10:58 AM
On the parts of the lawn where it is not competing with the normal grass, does it fan out low to the ground?
From here, it looks like crabgrass.
Bayer makes a great crabgrass, and broadleaf killer in one container.
The newer gal product comes with a battery powered sprayer...all in one. It can be refilled.
Bayer products are excellent.
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 08-13-2018, 11:00 AM
T77911S's Avatar
is that what grass looks like??
send it to me, only thing green in my yard is weeds
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 08-13-2018, 11:18 AM
drkshdw's Avatar
Looks like bermudagrass to me. The local extension office has this to say about it:
"Quackgrass and Bermudagrass is more difficult to control since there are no herbicides to selectively kill these without damaging the lawn. Also, pulling or digging is often unsuccessful as only a small portion of a rhizome remaining in the soil will generate a new plant. The best way to control quackgrass, is to spot treat weed-infested areas with glyphosate (Roundup, Kleenup, etc.)."
Old 08-13-2018, 11:26 AM
Unregistered
sammyg2's Avatar
If you dig down 4 feet and the replace all that dirt with perfectly sterile fill, you can get rid of St. Augustine. For a season or two.
There is only one product I know of that can get rid of that stuff without killing the fescue and I won't recommend it because it's safety has been called into question.
For reference it's called turflon ester.
Do your own homework, the EPA says it's safe but others don't agree and I don't feel like being a litigant.
Old 08-13-2018, 11:27 AM
canna change law physics
red-beard's Avatar
Yep, St. Augustine.
James
Red-beard for President, 2020
Old 08-13-2018, 11:29 AM
pwd72s's Avatar
Yep. I have a pretty big lawn, about 1/3 acre. Used to be a fanatic about it..spot kill bad grasses with roundup, then seed with desirable grasses.
Today? If it's green and kinda looks like grass, I just mow it.
Old 08-13-2018, 11:56 AM
brainz01's Avatar
I'd be worried about using chemicals to control St. Augustine. In my experience, you'd likely just kill everything else first. It's pretty tough.
Because it spreads with runners, it's not too hard to pull out of flower beds or other small/new areas it creeps into. Not sure it'd be easy to rip out a big established patch, though -- It gets pretty interwoven and matted.
Like all plants it needs sunlight -- and St Augustine seems to really like full sun and water -- it doesn't grow well under big shade trees. And I've learned that it dies pretty quickly if covered up with dirt or debris (like from a hurricane).
If you've only got a patch of St. Augustine and don't want to rip it out by hand, consider putting a tarp or heavy trash bags over the affected area for a couple/three weeks. Use a rake to clear out the dead grass and loosen up the soil. Re-seed with whatever grass you use in your area. The grass seed will regrow before the St. Augustine does.
And you will likely have to be vigilant about pulling any roots that regrow runners, but that should be pretty obvious and relatively easy to maintain.
Old 08-13-2018, 12:01 PM
Kentucky is too far north for St Augustine to be invasive like that...imo
98 Honda Prelude
22 Honda Civic SI
Old 08-13-2018, 12:58 PM
White and Nerdy
Tervuren's Avatar
I am dealing with something similar on a now less used gravel area.
Tarp works wonders, you will have an ugly patch, but short term pain long term gain I guess.
Old 08-13-2018, 01:03 PM
unsafe at any speed
wswartzwel's Avatar
Bermuda grass has a narrow blade... that isn't Bermuda...Bermuda makes a nice lawn..... What you have is Johnson Grass. https://www.google.com/search?q=johnsongrass&client=safari&rls=en&source=lnms&tbm=isch&sa=X&ved=0ahUKEwiC84ad6ercAhURC6wKHbz_DF0Q_AUICigB&biw=1363&bih=607
Round up will kill it.
Bill Swartzwelder
Old 08-13-2018, 01:04 PM
Slackerous Maximus
HardDrive's Avatar
We have the same problem up here in OH! Just this year, its been terrible. Its been hot and wet, and I think its the perfect combo for it. It did respond when I used crabgrass killer, but came back with vengeance.
2014 Cayman S, PDK
Old 08-13-2018, 01:11 PM
Edministrator
Steve Carlton's Avatar
A lot of Johnson issues lately.
Good post? Leave a tip!
O - $1
O - $2
O - $3
Old 08-13-2018, 01:18 PM
red-beard's Avatar
It also doesn't like to grow under about 80F.
James
Old 08-13-2018, 02:36 PM
red-beard's Avatar
Viagra ?
James
Old 08-13-2018, 02:37 PM
Brew Master
cabmandone's Avatar
Sheesh! 19 posts and no one got it right!!
Old 08-13-2018, 02:44 PM
