Alii&Maui
What is this and how do I kill it.
![]() ![]() ![]() This stuff is taking over my yard as well as my neighbors yard. We didn't have this last year but what we did have is "normal crabgrass" problems. I'm using Drive XLR8 to kill crabgrass but this weed/grass laughs XLR8 off. One lawn care professional said it's Timothy grass but looking it up on the net it's totally different. Any help with a description and treatment I'd appreciate.
1982 SC Coupe SCWDP#0087 KCSSL#0082 |
That looks like St Augustine. It's what passes for grass in Houston. Our lawns are made of it. It's a creeping grass (versus seed). Thick bladed, heat resistant, and tough.
You'll need to rip it out if that's not what you want as it will take over. |
In Houston we call it grass. We can't seem to get anything else to grow
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
First you need to find out if it's an annual or a perennial...
It looks like what we call annual crab grass, which means you deal with it next with crab-grass spray.
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
Cars & Coffee Killer
I have something like that in my yard, but we have freezing winters here and I thought St. Augustine wouldn't survive that.
I've tried to pull it and spray it. Nothing works. Next up: roundup.
Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." |
On the parts of the lawn where it is not competing with the normal grass, does it fan out low to the ground?
From here, it looks like crabgrass. Bayer makes a great crabgrass, and broadleaf killer in one container. The newer gal product comes with a battery powered sprayer...all in one. It can be refilled. Bayer products are excellent.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI |
is that what grass looks like??
send it to me, only thing green in my yard is weeds
Looks like bermudagrass to me. The local extension office has this to say about it:
"Quackgrass and Bermudagrass is more difficult to control since there are no herbicides to selectively kill these without damaging the lawn. Also, pulling or digging is often unsuccessful as only a small portion of a rhizome remaining in the soil will generate a new plant. The best way to control quackgrass, is to spot treat weed-infested areas with glyphosate (Roundup, Kleenup, etc.)." |
Unregistered
If you dig down 4 feet and the replace all that dirt with perfectly sterile fill, you can get rid of St. Augustine. For a season or two.
There is only one product I know of that can get rid of that stuff without killing the fescue and I won't recommend it because it's safety has been called into question. For reference it's called turflon ester. Do your own homework, the EPA says it's safe but others don't agree and I don't feel like being a litigant.
canna change law physics
Yep, St. Augustine.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Today? If it's green and kinda looks like grass, I just mow it.
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
I'd be worried about using chemicals to control St. Augustine. In my experience, you'd likely just kill everything else first. It's pretty tough.
Because it spreads with runners, it's not too hard to pull out of flower beds or other small/new areas it creeps into. Not sure it'd be easy to rip out a big established patch, though -- It gets pretty interwoven and matted. Like all plants it needs sunlight -- and St Augustine seems to really like full sun and water -- it doesn't grow well under big shade trees. And I've learned that it dies pretty quickly if covered up with dirt or debris (like from a hurricane). If you've only got a patch of St. Augustine and don't want to rip it out by hand, consider putting a tarp or heavy trash bags over the affected area for a couple/three weeks. Use a rake to clear out the dead grass and loosen up the soil. Re-seed with whatever grass you use in your area. The grass seed will regrow before the St. Augustine does. And you will likely have to be vigilant about pulling any roots that regrow runners, but that should be pretty obvious and relatively easy to maintain. |
Kentucky is too far north for St Augustine to be invasive like that...imo
White and Nerdy
I am dealing with something similar on a now less used gravel area.
Tarp works wonders, you will have an ugly patch, but short term pain long term gain I guess. |
unsafe at any speed
Bermuda grass has a narrow blade... that isn't Bermuda...Bermuda makes a nice lawn..... What you have is Johnson Grass. https://www.google.com/search?q=johnsongrass&client=safari&rls=en&source=lnms&tbm=isch&sa=X&ved=0ahUKEwiC84ad6ercAhURC6wKHbz_DF0Q_AUICigB&biw=1363&bih=607
Round up will kill it.
Bill Swartzwelder 2002 R1100S Prep/ 2024 Tenere 700 |
Slackerous Maximus
We have the same problem up here in OH! Just this year, its been terrible. Its been hot and wet, and I think its the perfect combo for it. It did respond when I used crabgrass killer, but came back with vengeance.
2022 Royal Enfield Interceptor 2012 Harley Davidson Road King 2014 Cayman S, PDK Mercedes E350 family truckster Steam locomotive. Yes, you read that right. |
Edministrator
A lot of Johnson issues lately.
Good post? Leave a tip! O - $1 O - $2 O - $3 |
Brew Master
Sheesh! 19 posts and no one got it right!!
