lug nut bolts for my Cayman
Put on new tires and the guys at the shop lost one of my lug bolt to the Cayman. I am having a hard time locating one locally, new or used. Off to the net I go only to found upon delivery that the new one's ball seat are much smaller. I can't seem to find any over the net (I suck at searching). Dealer? No need for titanium, shiny polish alum, or stainless lug bolts. I also discovered that the original bolt's bite is only 5 to 6 threads or just under 1/2" and there are wheel spacer behind the wheels. Factory 19" wheels, its an S. Where do you guy get your?
I am not sure where or how its measured? I assume the length is measured from the end of the bolt to the top of the washer just right under where the hex head starts?
I think I am looking for 55mm length, 14x1.5mm lug bolt?
Old 09-10-2018, 05:55 PM
pic
Old 09-10-2018, 05:56 PM
Oops, forgotten about our host. Just looked.
Old 09-10-2018, 06:47 PM
I think I bought 4 from PP when I first got my Cayman. Replaced the locks. Hate those things.
Old 09-10-2018, 08:15 PM
A930Rocket's Avatar
A 1/2” engagement? That doesn’t seem like a lot, but then again, isn’t the rule the width of the bolt?
Either way, I’d like to have more.
Is the spacer a factory item?
Old 09-10-2018, 08:30 PM
Not sure? I like to have a little more bite on those bolts also. Hard to find 50 mm ones with the bigger head. I suppose the smaller round head on those cheap bolts will do.
Yep, hate those locks
Old 09-10-2018, 08:36 PM
David's Avatar
There are plenty of sources for good aftermarket Porsche bolts with the proper sized spherical washers and in all different lengths. Like Pelican or ECS
Old 09-11-2018, 06:11 AM
'Proper' engagement is 1.5x diameter as a rule of thumb. I suspect a lug bolt has such a big safety factor that 1.0x is fine, but I would prefer the 1.5 rule be applied.
M14 should have 21mm of engagement if possible, at 1/2" you would be under the1.0 rule.
Thread length is almost always from the bottom of the head, i.e., the real thread part.
Old 09-11-2018, 07:08 AM
Did you get the memo?
onewhippedpuppy's Avatar
Just don't go too deep. Not sure about the Cayman, but some cars have through holes that can actually hit the hub or knuckle behind. Typically wheel spacers more than 5 mm will require longer lug bolts.
‘07 Mazda RX8-8
Old 09-11-2018, 07:22 AM
Zeke's Avatar
Remove the wheel spacers? If you have factory wheels I think Porsche engineering probably has the wheelbase spacing about right.
Old 09-11-2018, 08:31 AM
They could be stock. I've had several Porsches that were factory optioned with 5 mm spacers.
‘07 Mazda RX8-8
Old 09-11-2018, 08:54 AM
Thread length, got it, thanks.
Old 09-11-2018, 09:09 AM
Yep, 5mm spacers
