Oil cap residue question
Car is a 99 911. Pulled oil cap and looked like this? Wondering if I should even blow money on PPI. Coolant was clean. Thanks
Need to drive it harder (that's what she said)
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
Functionista
Classic sign short tripping. Happens more at low temps. I see some of these with this and really dirty oil. If it was mine I’d change the oil, start and run a few minutes and perform another change. Oil is cheap and you can use the first 9 quarts again in a lawnmower or beater oil using car.
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
Make Bruins Great Again
Short trips or not driven often can cause that. I don't feel it needs to have the oil changed twice but I would definitely change it more frequently whether or not it has accrued many miles.
Funny anecdote: I misspelled "definitely" and the choice in spell checker below the correct spelling was "effeminately". ![]()
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
Functionista
To clarify I’d only do a “double” change if oil was ALSO super black.
Thread Tools | |
Rate This Thread | |
