GM 8.1 Harmonic Balancer - 496 - How to Install?
Anyone know how to install the harmonic balancer? It is not keyed and a apparently an interference press fit?
I don't think you can heat the balancer, I don't think dry ice on the crank alone will do it, not sure how to press it.
I'm asking for a friend, but we are both stumped.
Old 10-22-2018, 08:33 AM
fastfredracing's Avatar
Never done one on an 8.1 , is there a threaded section in the snout of the crank? They've been doing this on other engines for years now. I have a tool that threads into the crank, and pulls it in.
No left turn un stoned
Old 10-22-2018, 09:46 AM
Old 10-22-2018, 09:55 AM
That's a GM tool, I assume?
Old 10-22-2018, 10:34 AM
That one is, but I have a generic kit that does them all . Ill loan it out if you need it. It is the correct way to install any pressed on harmonic balancer
Old 10-22-2018, 10:51 AM
Usually I put a big bolt in it and use greased washers to stack under the head to push it on, that or
All thread in the crank snout, with a thrust bearing and a nut to drive it on, it helps to warm the balancer with a hot plate.
1976 914
1986 951
Old 10-22-2018, 11:04 AM
Got it. Thanks for the help.
Old 10-22-2018, 12:00 PM
If you don't have the fancy tool, I'm sure this would do the trick.
Old 10-22-2018, 01:35 PM
D idn't E arn I t
RANDY P's Avatar
What I always did as a kid. It worked, as far as I know.
rjp
AOC/Hogg 2028
Old 10-22-2018, 04:19 PM
A930Rocket's Avatar
Without a keyway, etc. how do you keep it from moving?
Or is it so tight, it just won’t move?
Old 10-22-2018, 06:31 PM
I believe the interference fit prevents slipping.
Old 10-23-2018, 04:38 AM
